how to get 800 horsepower to teh ground
Yea i am in the process of piecing everything together on paper of what ill need for the car. It will be a m6 twin turbo 99 camaro, and i was going to go wiht a fully adjustable bmr suspension kit with a 9 inch ford. The car will se some drag srip use and will be drven daily in the summer just wondering what other guys out there are running in these hp numbers. and suggestions would be appreciated thanx.
And before you spend a lot of money on "fully adjustable" stuff, ask yourself how many times you will be willing to adjust those items such as the front upper and lower LCAs (every time you adjust it significantly, you will need a new alignment); although adjustments would come in handy with the torque arm, the rear LCAs if you are planning on running large tires or something, and the panhard rod to recenter the rear if you need to. Maybe that is what you referred to with the adjustable items. Just my two cents, good luck.
