REAR ride hight adjustment
Currently I am running the prokit with stock shocks, I have been for about 40,000 miles. I am looking into a coil over kit because I want adjustibility. I understand that Spohn has a rear coil over kit, but it is very expensive. I want to keep a lowered rear end, so if I just put QA1 single adjustible shocks on the rear, will their adjustibility allow me to get rid of the rear "sag" that has formed? How much could they allow me to pick up the height in the back if possible?
The rear Qa1's aren't coilovers, they only adjust the stiffness of the shock, not the ride height. Ground control makes an adjustable rear spring setup that you can use with your QA1s, it will let you change the ride height. Try searching for "ground control" you should get a few threads with more info.
