Best place for subframe connectors
Where's the best place to buy subframe connectors? And is the boxed and tubular design a real big difference? I have prokit and have clearance problems with my exhaust but will I really notice a difference between the two designs?
Between the two methods of steel construction--no. If you have clearance issues now you'll have your hands full with subframes in addition, but it shouldn't be THAT bad...just be careful. I have Jet-Hot LTs which hang similarly low and am going for UMI 3-point tubular subframes since they have the most clearance of any subframes I've seen.
Hello,
We have a wide selection of SFC's available. We offer both tubular and boxed as well as bolt in or weld in. Both the boxed and tubular will hold up to any thing you can throw at them and neither will reduce ground clearance. The tubular style does tuck up tigther and can not be seen unless you bend over and look under the car. If you have any questions regarding them please ask and I will be glad to help.
http://www.umiperformance.com/Search...?CategoryID=42
Thank you!
Ryan
Thank you!
Ryan
Please use the search feature, theres tons of information about clearence and material used to construct them. Theres a number of sponsors on the right that all carry subframes.
