Right front has a metallic tap everytime I go over uneven road
Preface: I'm no mechanic.
I took my car in to get 2 new tires put on and while it was there I had the shop check out a tapping noise that I kept hearing when I'd go over a bump. It is coming from the right front and it's very noticeable. Long story short, they said I needed a new control arm so I had them replace it, but it turned out they replaced the left side control arm by mistake. So replaced the right side control arm at no charge since they messed up, but the sound is still there.
Anytime I go over the slightest bump I hear this tap noise. I can push down sort of hard on the front fender and replicate the noise. Any ideas? And I'm not taking the car back to that place anymore for mechanical issues--just tires from now on.
I dont know about "metallic tap" but lower-ball joints are common items that keep noise (in most cars after some miles) when going over bumps or such, do you notice anything in the steering wheel when you hear the noise?
Originally Posted by 30thanniv
I had same problem. It turned out to be the caliper. I can't recall exactly what exactly caused it, but the caliper had side to side slack. I used a washer to shim it tight and no more noise.
I have had the same style noise ever since I did my first brake job on my LG C5 front brakes.
Where did you put the washer?
