Poll: sway bar or NO sway bar?
Re: Poll: sway bar or NO sway bar?
I keep a 1LE up front for street driving, but it comes off at the track. Definitely keep your rear one on for the track - and if you go to a larger size or better design (wolfe) it's definitely worthwile.
I am running a home-made bar similar to the wolfe and it keeps the car straight, but I can second Angie's noise comment.
Chris
Chris
!Dial-up Director
[quote]Originally posted by BIGBOS:
<strong>I wonder how it would be riding around with my stiff suspension and then trying to cut a corner...
is it that sloppy</strong><hr></blockquote>
With my eibachs and no front sway bar the car is still pretty stable on turns, not like it was with stock springs. <img src="images/icons/shocked.gif" border="0">
I took my sway bar out about a month ago. After driving for about 10 minutes, I got completely used to it. I don't drive my car in the rain, and I rarely drive nasty on the street so it doesn't bother me at all. I would not try chasing any Supra TTs through traffic though, thats for sure!
I had the bar off on my '99 but I decided to leave it on my '02. I forgot how much better the cars handle with the bar on.
LS1 Tech Administrator
It's cool to run without the front for draggin', but I'd never recommend pitching the rear bar...big mistake...as a matter of fact, I like an even bigger bar in back for drag racing, like the 25 mm GM bar.
On my new convertible, I run a front sway bar, but I crank the front Hal shocks to full loose, haha...works better than yanking the front sway bar with stock shocks...weight transfer is killer!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
LS1Tech Premium Sponsor
I had the swaybar off of my T/A, and I did enjoy it for the street. The front end would lift quite a bit more. However, I've yet to disconnect it on the SS. After crawling out of an '01 Lightning, the stock f-body cornering ability was less than I was used to. I've yet to NEED to pull the front bar with my current setup. I've only been to one track out of four that I've had to fight traction. All of that may change with the 3.73's and different converter. <img src="images/icons/grin.gif" border="0"> I'd be more likely to get a set of front Hal shocks than I would to pull the front sway bar.
Jason - The Suspension Techniques rear sway bar is great! I installed it on my T/A, and it made a great improvement. It was so drastic for daily driving and cornering that I couldn't tell that the front bar was removed. It also helped to keep the car more stable on the launches as well. I'll end up installing one on the SS before too long.
I've had it off, then put it back on. On ramps are sooooo much more fun in the 1LE now <img src="images/icons/grin.gif" border="0">
#34
I effectively had no front swaybar for a while, one of the endlinks was busted. Didn't really notice a difference .... until I put new endlinks on a few weeks ago, DAMN, there is so much less body roll now, particulary noticable around sharp corners. I can just SLANG the car through 90 degree intersections now <img src="images/icons/grin.gif" border="0">
#35
I have mine off now, but I haven't seen a difference at the track. 1.6's before and 1.6's now <img src="images/icons/grin.gif" border="0">
#37
<img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> Mines outta there <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Sean
Sean
#38
If you drive on the autobahn, you definitely need 'em, especially if you plan on runnin' with Mr. 911!!! <img src="images/icons/wink.gif" border="0"> <img src="images/icons/grin.gif" border="0">
#39
So, how exactly would removing the bar (or endlink) help you at the dragstrip? Always hear people talking about it, but don't understand. I realize that weight transfer is important on a launch, but how can this possibly help?
#40
1 Post
JackDaniels by removing the sway bar or end links you allow for weight to better transfer to the rear tires which allows for better traction. This only works well with drag radials or slicks, the effect is neglible with street radial tires.
