How many miles are the factory sway bar endlink bushings good for?
I have 53,000 mature-driven miles on my 2002 Z28. I still have the factory sway bar and the factory rubber endlink bushings. I still have the factory springs. Now, I've been reading in some posts that the factory endlink bushings don't last that long. How many miles should I expect my factory endlink bushings to last? Also, are there any side effects in using a bigger front sway bar with factory springs and Bilstein HD's? Thanks in advance for the info.
I just replaced my stock sway bar with a Strano set and the endings at he same time..mine had ~35 on them....they were ugly bad...still worked..but very degraded
You just need a poly set..the hardware is the same..really get new hardware when you up grade as part of the package
