HELP! torque arm angle right?
Old May 12, 2002 | 08:19 PM
highgmc's Avatar
Default HELP! torque arm angle right?
just installed a spohn torque arm, Is this correct to make -2 pinion angle?
driveshaft angle= -1
rear angle (on flat spot of torque arm) -3
Is that -2? OR -4? damn I should have payed more attention in school! <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old May 16, 2002 | 07:57 PM
Phate's Avatar
Default Re: HELP! torque arm angle right?
Terry,
That should be fine...true pinion is:
PINION ANGLE - DS ANGLE
-3 - (-1) =
-3 + 1 =
-2
You should be all set...I usually turn mine to 0 when driving around so that I don't wear the bearings...but you can probably get away with -1 or -2 for awhile!
Scott
Old May 16, 2002 | 11:07 PM
highgmc's Avatar
I thought it was ds angle- rear end angle?
not rear - Ds??
