C5 brakes
Old Jul 12, 2002 | 10:58 AM
Beth's Avatar
Default C5 brakes
Is it possible to use this setup on my 98 Z. I did a search and can't find anything to answer this. Maybe I am not typing in the right things....
Thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Beth
Old Jul 12, 2002 | 01:51 PM
1COOLPC's Avatar
Default Re: C5 brakes
They won't switch over Beth but why would you even want to? The systems are very similar in performance, if not exactly so.
Old Jul 12, 2002 | 02:20 PM
Beth's Avatar
Well, there is a set avalilable to me so if it were possible why not, ya know......... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 12, 2002 | 02:46 PM
ibjamin's Avatar
Yes you can get a kit from the following:
http://www.nashvillespeed.com/Fbody/...s/brakekit.htm
I am about to install a set on my 99 Z28
George E.
Old Jul 13, 2002 | 08:29 PM
mitchntx's Avatar
The requirements of a brake upgrade are:
Larger rotor (more swept area)
Larger pads (more swept area)
pad compound (more heat tolerant/better bite)
Fluid and lines maintain what you have for a onger period of time under EXTREME comditions.
So, replacing the F-Body rotor ~12" with a C5 rotor ~13" would yield better brake performance.
Now, to answer your question ...
The caliper mounting bracket geomether is wrong to just fit up C5 rotors. It requires a bracket to be machined to correct that geometry.
LG Motorsports makes a kit for under $500 that will put 13" rotors on your F-Body.
