wheel size combination??
<strong>Would I get better traction/handling with wider wheels in the rear. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Those cars have better weight distribution than the Camaro, so they can use the small/large tires to their advantage.
The more nose-heavy f-body's handling will be more balanced if the tires are the same front-to-rear. Wider tires and wheels are for looks and straight line traction. For the street, 17x10 or even 18x10.5" will fit under the front fenders.
Also, you want to keep the same tire diameters front and back so as not to throw off the ABS and ASR.
For the strip, go with Kent's recommendation.
DaveH
