HAL QA1's Can you drop the car with these springs? And out of curiosity what setting do yall run around with for everyday driving and what settings for the strip and such? Thanks -Matt |
Re: HAL QA1's I got HAL's all around...you can adjust the ride height of the fronts I think, but you don't want to go too low otherwise you will deal with a lot of bottoming out... For the street I got the fronts set at 6/6 and the rears at 3/3... For the track the fronts will go to 2/2 and the rears I will play with all depending on the launch... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> |
Re: HAL QA1's Thanks, did you do springs also or are you using the stock springs? |
Re: HAL QA1's I used their springs in the front, and the eibachs I had before in the rear.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> |
| All times are GMT -5. The time now is 12:03 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
