Bent Panhard rod any effects?
somehow bent the bmr panhard rod underneath my car, not to bad but bad enough that you can see the bend. Adjusted it so that the rearend was center again. Anything else that i should look for, or should i buy a new one?
Re: Bent Panhard rod any effects?
You're OK to just drive aroung, but if you're going to load it up....as Dark Ages noted, it will likely bend more...
Gordon
www.provenperformanceconcepts.com
<img src="http://www.provenperformanceconcepts.com/PPC%20BANNER%20468x60.jpg" alt=" - " />
Gordon
just wanted to say thanks for the replies. I just do driving around on it, so i think unless i notice anything out of the oridinary then i will just deal with it.
