will z06 calipers fit on the rear?
say you got the lg motorsports brake package and got the z06 fronts, would the z06 rears be a staight swap? anyone know?
Re: will z06 calipers fit on the rear?
i'm very sure that i know someone who has done that. just an FYI - its the same cailper you already have, just powder coated. i sugest you paint or powder coat yours.
well i'm lazy and if i can directly bolt up a factory caliper w/a factory finish id much rather do that. painting will be a last resort. does anyone know? i know a few people on this board own a vette and a f-body how bout some help fellas
A friend of mine works a GMMG and works on the ZL1 Camaros. One of the upgrades they do is putting the Vette brakes on the ZL1. The front requires special brackets that ran $500 for the set. Not sure about the back. With that kind of cost, why not just do the Wilwood 4 piston package? Hope this helps.
I think i read somewhere that the physical dimensions are the same, but the fitting for the brakehose and/or bleed screw were in different locations.
I think the conclusion was that it will still work, but i'm not sure
The corvette brakes (at least the Z06, and I believe it is all of them) are pressure cast (not really forged, but better than regular cast) and seem to eliminate "spreading" (under extreme use, the cast f-body calipers have in some cases started to open up or bend outward). The F-body calipers are regular cast aluminum. THere would be a posible performance upgrade (if you use the brakes that hard) by switching to the vette calipers. I am looking into this change for my own car as well (autocross and track days). However, I don't know if they will swap or not. I'd contact Scoggin-Dickey Chevrolet (www.sdpc2000.com) adn see what they can tell you (and they will likely have a good deal on the calipers). Good luck.
TurboTnZ06 you wouldnt have any close up pics of the rear calipers and how they mount that you would be willing to post do you?
well i called around and no one has a clue whether they fit or not so im gonna have to find a vette and check it out for myself. anyone in new orleans have a z06 i can compare/contrast to? maybe take it for a spin? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
EDIT:
anyway i will keep yall posted on what i find out
EDIT:
