wierd noises from rear
i get this clunking or rattling kind of sound when i hit small bumps in the road. almost liek a rattling heat shield (which i dont have) Cant think of what it could be. i also get this soud of lieka low tire or some sor of rubbing when i am at slow speeds
I cant figure out if its a suspension situation, a rear situation, aftermarket tires (the clunking occured with both KDW's and ET Street Radials)
any ideas anyone?
any ideas anyone?
I have the same problem. Tightened the spare, exhaust and from what I could tell nothing is loose. It is a "thud" sound (something hitting the floor pan)coming from the right/rear also over small bumps in the road. My dad said it sounds like a bolt is loose on one of my shocks, which would make sense. I am going to look at it this weekend and post results.
Copy & Paste Moderator
I have plenty of clangs and bangs from the rear of my car (mostly from the right rear). I dont know what it is and its getting worse. Mods in sig (my rod ends are not loose and all bolts are right).
