rod ends vs poly bushings
Copy & Paste Moderator
Poly/rod here.
If you want all-out control go rod/rod.
If you want comfort, stick with rubber (keep the stockers or get 1LE).
If you want a compromise, get poly/rod.
Don't get poly/poly for a car you want to handle properly and not overstress the mounts (too much bind). Should be ok for a drag car though.
