Front brake problems
Old Sep 29, 2006 | 08:03 PM
95FbFormula's Avatar
Default Front brake problems
I just changed my front pads today and when i took it for a test drive the pedel felt like it had very little pressure does it sound like I have to bleed them or what. I didnt have the problem before i changed them. Now i can hold the pedel to the floor and git the gas and still push the car forward I dont even have enough peddle pressure to torque up???
Old Sep 30, 2006 | 01:24 PM
CW00BlackTA's Avatar
Sounds fishy. What exactly did you do when you changed the pads? Typically you don't disconnect any of the lines and shouldn't lose pressure. If the caliper dropped, you may have damaged a brake line (leaks?). I would suggest checking the lines/calipers for fluid leaks and if you don't find any, bleed the brakes and see what happens.
