anyone running a de-coupled TA?
The UETA definitely seems to be sensitive to the car setup. If you are on stiff springs and have rod-end LCAs, you will be on familiar ground.
I believe Jim and I were both at or near stock spring rates when we installed the UETA, and we were apparently the first to try that (he mentioned having #004, and mine is #007). Both cars/arms were definitely nowhere close to properly set up when Sam drove them (a month or so apart), and that makes a HUGE difference. Any impressions drawn from that experience are totally irrelevant, except that it would be fair to say that a decoupled arm is not a simple no-brainer bolt-on - it does require some tuning.
A good analogy would be installing an aggressive cam. Until you get it tuned it's going to drive like cr*p.
I also believe that both Jim and I went to spring rates in the ballpark of what Sam is running before fully sorting out the arm with stock rate spring. So, anyone attemping to install the UETA with stock springs and LCAs is going to be plowing new ground.
Suffice to say I haven't taken my UETA off the car
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
LS1TECH Sponsor
Suffice to say, I haven't taken my long, trans mount arm off, and the car does quite well thanks. Pick your poison, that's what I said before, and it's what I am re-iterating now. This is the internet folks. You will NEVER get all the answers you should have by online chatting. *pick up the phone and ask questions*, to whoever they may be.
__________________
Originally Posted by Sam Strano
In short, I know I'd appreciate Sam being able to tell folks what Sam's done, and not you guys who don't know every single thing I've ever done.
However, if you are expecting those of us who actually have the UETA on our cars (five in this thread by my count) to simply and cheerfully accept comments like:
Alas, I'm just smart enough to not re-invent a wheel that's not square.
As for those who have made such things work, be careful. That's a relative term and you need to know what it's based on. Lots of folks say something works, like stock shocks on Sportlines.
In short, I know I'd appreciate Sean [et al] being able to tell folks what Sean [et al] has done, without Sam riding in yet again to dismiss it all as idiocy from incompetant yahoos. Any courtesies you may feel you are entitled to work both ways.
Now, I'm not out to sell anything. I have no financial interest in anything automotive outside of (possibly) some indirect investment through my 401K. I have absolutely no motivation for bias. I have quite openly documented my positive and negative experiences. There's no "snow job" or "rose colored glasses" at work here.
So, Sam, got anything constructive to add? How does the HA design compare to the UE design? What car did you test it on, and how was it set up? What didn't you like about it? Was there anything you did like about it? How might it have been improved?
[disclosure: this post has been heavily edited by me]
Well, my PHB has never caught any road kill, but it's only lowered slightly. I have, however, caught road kill with my the safety loop of the torque arm, which is roughly the same height as the Kmemeber. I was still finding bits of "jerky" several months later.
I heavily edited and added to post #26, because that's where the changes seemed to fit.
#33
I wanted to add a few other data points as far as cars that are set up and working. One of the most important variables when working with this TA is the LCA bushing stiffness. Rod ends are ideal, but 1LE bushings can also work well. The stock "star" bushings DO NOT WORK.
Spring rates seem to be of less importance and cars from 150-600lbs rear spring rate have have been sucessfuly setup. I have not set up a car on stock spring rates. I believe the largest part of Jim's issues are the stock "star" LCA bushings.
I think we've made about 20 units to this point. I'm not certain how long production will continue.
As far as the differences between the Herb Adams unit and this one, I haven't seen a Herb Adams unit except in pics, but it appears that there is no TA safty loop to keep the TA off the ground or away from the DS, the accel beams in the Adams unit are cantileavered, and the mount points do not distribute the load as well to the chassis. They appear to be identical in theory.
Jason S.
Jason S.
#34
There are quite a few big differences between the VSE arm and the UE arm. Experience with one does not equal experience with the other any more than experience with "a torque arm" equals experience with every single arm made for these cars. Experience with the VSE arm will be very helpful in threads where people are asking for experience with the VSE arm. But it's about as useful to questions of the UE arm as experience with the Jegster arm is for questions about the Random Tech arm.
#35
...One of the most important variables when working with this TA is the LCA bushing stiffness. Rod ends are ideal, but 1LE bushings can also work well. The stock "star" bushings DO NOT WORK.
Spring rates seem to be of less importance and cars from 150-600lbs rear spring rate have have been sucessfuly setup. I have not set up a car on stock spring rates. I believe the largest part of Jim's issues are the stock "star" LCA bushings...
#36
alright so im doing my best to take this all in.. one question, does the PHB need to be rod ends or 1LE bushings for the UETA too?
thats what im looking for
I know you have commented in the past that too much anti-squat can cause corner-exit understeer, which is certainly a theoretical possibility, though I've found I can get on the gas sooner coming out of a turn with the UETA.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#37
Hey speedfreak,
The PHR should be rod ended IMO, but that won't effect the TA. Anything that stiffens the lateral response, and at the same time reduces any hint of binding can't be a bad thing![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Jason S.
Jason S.
#38
LS1TECH Sponsor
Absolutely any car used for any kind of handling use should have a double rod-ended PHB. Completely agree on that.
__________________
#39
Hey speedfreak,
Jason S.
Jason S.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#40
Originally Posted by z_speedfreak
and once ive got enough disposable income id love to jump into autoX ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
