LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Suspension & Brakes (https://ls1tech.com/forums/suspension-brakes-16/)
-   -   Good beginner's setup? (https://ls1tech.com/forums/suspension-brakes/594220-good-beginners-setup.html)
Out1aw Oct 18, 2006 01:21 PM
I am almost done paying off my Camaro, and really want to increase the handling first before anything else. This is not a dedicated drag car, but a daily driver that I want to be able to go fast on the track and through the mountains/road courses (im about 30mins from Road Atlanta).
So here is the setup I had in mind:
1. SLP Bilstein's
2. Eibach Pro-kit
3. Hotchkis sway bars (front and rear)
4. Panhard Rod
5. LCA's w/ relocation brackets (weld or bolt in???)
6. Torque Arm
7. Subframe Connectors (weld or bolt in???)
Is that a decent setup? Thoughts, opinions, and comments are welcome!
MeentSS02 Oct 18, 2006 01:44 PM
Call up Sam Strano and talk with him. He'll send you in the right direction.
Ace$nyper Oct 18, 2006 02:19 PM
+1
Sam knows what he's talking about has awesome products.
But as far as what you've listed some are debatle and others will be based on brand and pricing.
Sam Strano Oct 18, 2006 03:26 PM
#4 is a good idea, *if* you use the right type. Most everything else on the list... I'd mostly likely recommend other things. :)
trackbird Oct 18, 2006 06:23 PM
1. SLP Bilstein's
I'd do HD's before SLP's, and I'm not sure about the new version of them, I might do something else at that point
2. Eibach Pro-kit
depends on what you want to do, there are better choices for performance, but the Pro kit isn't inherently bad/evil
Do the front only, or a Suspension Techinques front (and save money) or one of Strano's 35mm hollow bars and save money, the rear bar is just "too much" for most applications
4. Panhard Rod
A good idea, there is not a real disadvantage to using a rod/rod style PHB, but there are several choices and many are good
not needed on most cars, but can be useful. Many don't have the holes in the right place for handling applications
6. Torque Arm
not absolutely required for handling
Not a bad idea, but many cars do very well without them
Added my basic thoughts in bold. We'd need to know more about what you really want out of the car. How low do you want it? Are you concerned about appearance and do you want a specific ride height? Do you have long tube headers (or will you?)? And, a host of other information.
Foxxtron Oct 18, 2006 06:45 PM
https://ls1tech.com/forums/suspension-brakes/513475-canyon-carving-street-suspension-setup-review-long.html
This is a pretty decent sticky to reference what you can do AFA modifications are concerned.
Out1aw Oct 18, 2006 07:08 PM
I'm not wanting an extreme drop but do want it lowered about 1.5" at the MOST. I will not be running longtubes, but midlengths are on the list with a normal cat-back (no true duals). It will be my daily driver and I want something that can handle extremely well with canyon-carving and road courses, but not on a competition level to where it becomes uncomfortable to go on long trips. It will also need to be a list of parts that are good for a budget build up. Therefor I can't really go with Koni shocks or other various pricey pieces.
jdhommert Oct 18, 2006 08:31 PM
How about Koni shocks, and stock springs. You can lower it with Koni shocks about 3/4"
trackbird Oct 18, 2006 09:38 PM
Shocks are the most expensive part of any suspension build up (for performance shocks). They are also the most important. Think of shocks as the cylinder heads of the suspension. They will have the most influence on your results. Poor shock damping will cause a rough ride, too much shock damping will cause a rough ride and I could go on.
You could start with sway bars and an alignment. A 35mm front bar and performance alignment will go a long way in getting you started and aren't too expensive. Then save for shocks (and possibly springs). However, as Foxxtron said, there is a canyon carving sticky that might be just what you need, and it's a bit of a budget oriented build up (as I remember, I might have to go re-read it).
© 2026 MH Sub I, LLC dba Internet Brands
