does a WILWOOD 6 piston kit fit TT2's?
I can't say 100%, but the C5 conversion won't clear those wheels, and the Wilwood kit seems to need spacers on several wheels. My best guess (and it is a guess) is that they will not fit. See if someone will drop in that can verify it for you, but I don't think you'll have any luck with that combo.
http://www.wilwood.com/PDF/ds446.pdf
go to pg.3, then reference the dimensions from there. Before EVER investing in a big brake kit, always obtain either a fitting template sheet and/or a schematic of the brake kit's clearances.
