Does UMI answer YOUR PM's?
Old Nov 4, 2006 | 10:45 AM
sdiddy's Avatar
Default Does UMI answer YOUR PM's?
I know it's a long one but I've sent this 2x and gotten NO responses: I've had the adj. tunnel mounted TA for a while and had been experienceing bad vibrations. I have the p. angle dialed in right and the TA is set at -1*. All the bolts are tight as suggested. I noticed in a thread a couple of days ago you guys mentioned to make sure the TA and DS are parallel. Mine is not exactly parallel. I've moved the g-load brace as far as possible and it's still off. The TA mounts to the Moser with the 1st set of bolt holes. I could make everything parallel if I used the 2nd set of holes, but on the Moser there is a lip preventing the TA to be moved over to use the 2nd set of holes. Should I grind down the lip on the Moser to get the TA to be able to slide all the way over to use the 2nd set of holes so everything would be parallel? Sorry for the long post.
Old Nov 4, 2006 | 05:19 PM
sdiddy's Avatar
Can anyone else offer any advice on my issue witht he TA?
Old Nov 4, 2006 | 05:37 PM
Fulton 1's Avatar
Have you tried calling Ryan?
Old Nov 4, 2006 | 05:43 PM
3.8to6.0's Avatar
Just give Ryan a call, he wouldn't mind talking to you
Old Nov 4, 2006 | 06:05 PM
UMI Performance's Avatar
Hello,
I will reply to your PM sometime this weekend. I have just been very busy and trying to answer them order, I still have quite a few unread.
Sorry for the slow response, Thanks
Ryan
Old Nov 4, 2006 | 06:31 PM
sdiddy's Avatar
Thank you. I look forward to hearing your reply.
