adjusting parking brake
I have to pull my parking brake lever almost straight up to get it to work. Anyone else have this problem? Is there anyway to adjust it? I tried searching but came up with nothing helpful. Haynes manual doesn't have anything either.
A lot of people have this problem. I looked into the Haynes manual and it said to take it to a dealer for them to adjust it.
The more expensive Helms manual should tell you how to adjust it and I'm sure a couple of people on here could tell us how to do it.
e-brake adj.
under the rotor there are small conventional breke shoes,there is a small thumb wheel at the bottom,it's just like adj. the old style brake shoes. there might be a slot to adj from inside the backing plate. i changed the rotors and adj. mine hope this helps 02 hawk blk,blk m6. and i approve this message !
Here's the thread.
https://ls1tech.com/forums/showthrea...=Parking+brake
or here is the one post you really need to read
https://ls1tech.com/forums/showpost....36&postcount=7
FYI the teeth need to be turned the opposite direction of what the post says. I learned this after messing with mine for a while and realized the brake was only getting worse
