car not level after lowering
I've got a 99 WS6 that I put Intrax springs on. The rear of the car sets 1 1/2 inches lower on the passenger side than the driver side. The rearend is not centered as the pass. side wheel sets in more.
I know I need an adjustable PHR to center the rear but will it correct the height problem?
Anyone else experience this? Any help appreciated.
Thanks, Mike
Thanks, Mike
Originally Posted by CW00BlackTA
Check the orientation of your rear springs in the spring perches. It can make a big difference.
I would check that and make sure the spring is seated correctly in the rubber boot that sits on top of the spring. If the spring is turned a little different than the other side it will make a difference.
Yeah, I looked at that the other night and everything seems right. I rotated the spring but it made no difference in the height.
This weekend I'm going to switch sides with the springs and see if it follows the spring and go from there.
