broke my rear sway bar
broke my rear sway bar (pics)
i was looking at my car today and it was sitting uneven when i look under the car i saw that the rear sway bar was snaped on the passenger side right after the mount and i was wondering why this happened i dont auto-x my car and nothing happened drastic that would cause this?
edit:added pics 4 posts down
LS1TECH Sponsor
Impressive.... Never saw that before. Can't tell you why, the endlink is much weaker than the bar, and should have broken first. I guess either some serious rust or just bad steel.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
willing to bet that someone tightened it while the wheels were off the ground. SO even when your car sits flat on the ground, your swaybar had some serious pressure on it. SOmeone didnt preload the suspension and do it the right way.
