what to get to help 400+rwhp on stock rear-end?
ok so I heard that getting control arms, subframe connectors, etc will help a stock rear end out.
my mods are in sig. I have 3:42 gears and I want to have this rear end last as long as it can. I'm getting ready to get a new clutch (maybe LS7 or better). my car will be lowered about 1.25" with 17" x 10.5" wheels in back. what should I look into getting as far as suspension parts?
thanks!
thanks!
Originally Posted by HawkFanatic
High Performance Pontiac or GMHTP did an article on how to build a 10 bolt to handle 425rwhp... things like straightening and welding the axle tubes, new axles, girdle...
Originally Posted by mitchntx
I would suggest you chip it.
Insert a 2x4 chip under the carpet, about where the throttle pedal hits.
does a 9" rear end refer to the gears itself? and when guys go to the 9", is it just the gears they change out or what?
and can I just take the diff. housing cover off & stick one of these in place of the stock?
because I got it stuck in my head that a 12 bolt is only 2 bolts stiffer than stock, which probably isn't necessary if you're not taking your car to the strip every night
https://ls1tech.com/forums/showthrea...ighlight=moser
^ The thread in that link was just talking about the center section. When people talk about getting a 12 bolt or a 9", they mean the whole package, i.e. housing, gears, diff, axles. This will run you over $2,000, but it's worth it if you're launching hard and you don't want to tow your car home after a couple of runs.
thanks for the input guys.
I read somewhere that you can change the stock girdle & studs, and go with an upgraded posi unit to strengthen the 10 bolt. but then I also read where it was costing up to $1200 and $1500 to beef it up. therefore what I need to do is drive my car safe and save money up for a 9" or 12 bolt.
Yup.
I blew $200 on gears, $100 on an install kit, $200 for labor, $155 on a cover, and $25 on a stud kit.
That's $680 to beef up the 10 bolt a little bit.
I know a new posi is $300+ and I don't have a clue how much axles, or welding the tubes would cost, but I'm betting $1200 is a good estimate for a total if I did the rest.
Originally Posted by Ouija
Yup.
I know a guy that works for a tuning shop that has the stock 10 bolt...stock gearing, and has done N2O launches on the car for the last 50k+ miles...plus the car has additional mods. I think his car has over 100k miles on it, and he says it holds up quite nicely.
His claim was that the guys who replace the gears inside the 10 bolt are the ones that jack it up. Apparently (according to him), the 3.42 gears are quite strong for what they're worth.
I've run into the same problem now...I'm going turbo...spent the $$ on that and now have limited funds for the rear-end. Hopefully, street tires + granny shifting = lasting 10 bolt.
Originally Posted by candlelit
how is your 10 bolt holding up?
I also don't do neutral dumps on the thing. My trans should be able to handle a neutral dump, but I don't see any reason to abuse it like that.
Heads and Cam are going in this month, and I'll still be spraying out of the hole, so we will see how it holds up then. It's already handled more than a lot of people claimed/thought it would.
I talked with John @ Fuddle and he says he has hundreds of passes on his 10 bolt (girdle + stud kit) without issues. (Also an auto with spray, but he has H/C already.)
