Anything cheaper than Konis that work well with lowering springs?
I'm hoping to purchase some wheels in the near future and would like to lower the car a bit for a better look. I've seen that the Koni shocks are the most popular, but I'm curious if there are any other shocks that work well and cost less.
My car spends all of its time on the street, usually just driving to and from work. It's not my daily driver and I don't drag race or autocross, so performance isn't nearly as important as reliability and comfort.
I'm looking primarily at the Hotchkis springs because I only want a small drop.
Thanks,
Josh
Thanks,
Josh
You can get Sam Strano to re-valve a set of Bilstein HD's that should work well with Hotchkis springs/the rest of your setup. Out of the box, Bilstein HD's aren't intended for use with higher rate springs, but they can be re-valved to work well.
-Mike
-Mike
Yes and no, something like Bilsteins will "work" but not very well, simply because they aren't made to handle a lowering spring. Like was said, the cheapest option is probably re-valved Bilsteins.
Originally Posted by May Spin
Around $500.
Originally Posted by Josh
Thank you, all, for your input. Generally, how much should one expect to pay for a set of four of the re-valved Bilsteins?
Josh
Josh
Your plan:
Springs (225)
Bilstein HD - stock (400)
Results - 625 plus install, you'll hate it because the stock HDs can't take the lowering springs, AND it'll be too stiff for your claimed desires due to the spring rates
So, at a minimum, you go:
Springs (225)
Revalved Bilsteins: (500)
Results - 725 plus install, and a bit too low and a bit too stiff for your desired application
And here's another option:
Koni SA (740 or so)
Stock springs (0)
Remove upper coil spacer in rear, replace with 1 turn of heater hose over the upper coil (0)
Set front spring seat on lower perch in front (0)
Results
- better handling than you can likely imagine, adjustable to use and taste
- About 1/2 to 3/4" drop front and rear, IMHO perfect for the real world
- within 115 bucks of your plan
- AND - you'll own shocks you can later use with pretty much ANY spring out there and get great results with, if you decide to go lower, stiffer, or better handling.
Springs (225)
Springs (225)
Koni SA (740 or so)
Stock springs (0)
Results
LS1TECH Sponsor
Originally Posted by BitViper
He only re-valves the fronts..and actually he has Bilstien do them Before they drop ship them to his customers..you do need to call sam to get his specifications
And they are $530 for the set of 4.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
