Adjustable Suspension parts or not???
wanting to go with LCA's, Panhard Bar, Torque Arm, Front & Rear Sway bars.
i what are the benefits of getting adjustable parts and is it worth the extra money?
Copy & Paste Moderator
since no one searches anymore....
Here are some of the many many many many threads on this subject:
https://ls1tech.com/forums/suspension-brakes/560141-how-why-suspension-adjusted-need-help.html
https://ls1tech.com/forums/suspension-brakes/492790-panhard-bar-adjustable-non-adjustable.html
https://ls1tech.com/forums/suspension-brakes/488914-torque-arm-rcb-phb.html
https://ls1tech.com/forums/suspension-brakes/478148-what-gain.html
https://ls1tech.com/forums/suspension-brakes/476806-adjustable-lcas.html
https://ls1tech.com/forums/suspension-brakes/473481-panhard-pictures.html
https://ls1tech.com/forums/suspension-brakes/627911-double-rod-end-vs-rod-end-poly.html
Here is my quote from another thread:
A search will get you many more threads on this subject.
Originally Posted by VIP1
Adjustables allow you to adjust the rear axle left/right to center it (left/right) under the car. This isnt necessary for stock right hide, but is necessary when the ride hieght is changed (ex: lowering the car).
* Adjustable LCAs allow you to adjust the rear axle forward/aft/diagonally.
* Adjustable PHB allows you to adjust the rear axle left/right.
* With both you can adjust the rear axle in all horizontal directions (left/right/forward/aft/diagonally) to center it under the car.
* Ajustable PHB isnt necessary for stock right hide, but is necessary when the ride height is changed (ex: lowering the car).
That being said....
I have stock right height, but I do have adjustable Spohn rod/poly PHB and LCAs. They allow for the adjustment of the rear axle in all horizontal directions (left, right, forward back, diagonally). My rear was a bit off with the stock parts and is all straight now with the adjustables (adjusted by the mechanic during an alignment...you have to ask for it and may need to convince them to do it).
That being said....
CaMaRo67RS355, you are the uncrowned king of starting new threads.
But IMO, if you're not lowered or anythings, get poly/poly non-adjustable. I've got the poly/poly non-adjust LCAs and PHB and they do real good. I guess for the extra coin, if you think at some point you will want the adjustability of suspension parts, then get the adjusties. Some good links in the post above BTW.
Originally Posted by CaMaRo67RS355
the reason i post so many threads is because my computer is crap and searches dont work well with it...
my computer is crap so the searches do not want to work - it will freeze my computer up
That being said, It does still work and the mods have added the google option too. Although the google option is less targeted, its faster and can find obscure old threads. I typically try the normal search feature first. If that doesnt work, then I use the google search option. I used the "advanced search" to find the threads that I posted above.
