I want the z28 to feel planted on the ground.
When I was being mischievous driving the Z 130+ mph, the car felt like it was floating on air. I didn't like that feeling, last time I felt that way in a car was when I had my former DD Chevy Corsica do 120+ MPH.
How can I get rid of the floating feeling at high speed? stiffer springs/better shocks? LCAs? adjustable PHB? A wing?
I'm not a suspension guru and would strongly recommend to look around here (this topic has been discussed in the past) or talk to someone like Mr. Strano, but because this "floating" was my biggest problem too, I just want to share my experience.
I changed a few things: LCA's, PHB (both poly/rod-style), SFC's and a STB... but the improvement was only marginal... Finally I bought the Bilstein Tuned Suspension Kit (BTS). I decided to use only the Bilstein-shocks together with the stock springs... (Did this because of some useful hints from very experienced users here, one of them is mentioned above).
From the moment, the bilsteins were on the car... The "floating ship"-feeling was history!
Please don't get me wrong... I'm not able to say, that is the best solution at all or for you. It just worked for me...!
I think quality shocks, matching your springs, is the most important factor!
That's the lesson, I had to learn....
Holger
Holger
Hey My DD corscia tops out at 111 or something dang it...its a 95 model.
Anyway you need some good shocks, Konir or revavles and good speed rated sticky tires. And I have "heard" at those speeds you will be just fine
Be safe. Good luck.
Be safe. Good luck.
Holger
Holger
