Rear swaybar installation question
ok, in the instructions that came with my sway bar kit, it says to jack the car up by the body to do the installation of the rear sway bar, but in the installuniversity instructions, it said that they initially were just going to use rhino ramps, and only changed because they could get better pictures with the tires removed.
will it hurt anything to just use the rhino ramps, or should i jack it up by the body and put it on jack stands? does it really make any difference?
I'd back the car up on ramps, lift it a bit by the rear axle, put jack stands under the rear frame rails, remove the rear tires then change the bar. I put a bit of silicon grease on the poly bushing, not only on the bar but also the bar ends.
LS1Tech Premium Sponsor
The rhino ramp installation is fine. The biggest thing we recommend is to have the suspension at ride height when you tighten down the end links this will help prevent binding on the bushings.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Lee Spicher
(813)986-9302
Don't be alarmed if you break your stock endlinks. All of my stock endlink nuts were rusted to the bolt. Taking the wheels off will make it a lot easier to access the endlinks. I was a noob when I changed mine 4 years ago and I had no room to remove the rear left endlink and had to cut it with a hacksaw.
Lee Spicher
(813)986-9302
Lee Spicher
(813)986-9302
Originally Posted by trackbird
As Lee said, tightening it down a ride height is important. It often will elminate some of those annoying squeaks that you can get if you tighten it with the axle hanging.
cool, thanks guys....that's what i was looking for. plus, i think it will be less hassle using the ramps anyway....won't have to remove the wheels, which is kinda what i wanted to avoid doing, assuming it didn't cause problems.
i'm assuming the same holds true for the front swaybar also, right? cause that's how i did it on the front....
Would it be the same as ride height if once you replaced the swaybar you brace (under load) the rear axle on jack stands so you could still access them to tighten up?
Lee Spicher
(813)986-9302
