steering column is loose, anybody know how i can fix it?
Old 02-09-2007, 02:13 PM
HawaiianZ28Rider's Avatar
Default steering column is loose, anybody know how i can fix it?
i took my car for inspection and it failed, the cause was a loose steering column
could anyone on here please tell me how i can fix this?
Old 02-09-2007, 03:05 PM
mitchntx's Avatar
Loose as in flopping around in the car or loose as in play in the steering?
The column has 2 support nuts above the brake pedal.
If the steering is loose it could be tie rod ends, steering rack or even a rag joint.
Old 02-09-2007, 03:49 PM
LS1TECH Sponsor
Sam Strano's Avatar
I bet he means the tilt mechanism is trashed and the wheel moves around when driving. Common with this type of GM column, and exactly why anyone who drives my car gets a lesson to NEVER pull on the wheel. The internals wear out, and bolt hold egg out.... really the only fix if this is the problem is a new column.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 02-09-2007, 06:13 PM
damn this sucks haha
yea if you pull on it or move it up or down, it budges
Old 02-09-2007, 08:49 PM
mitchntx's Avatar
Actually, GM makes a kit to replace all the bearing inside column. It's only about $25 and is the same kit they've been selling for years.
I trashed my column when installing a quick-disconnect ...
Old 02-12-2007, 11:34 AM
LS1TECH Sponsor
Sam Strano's Avatar
Here's hoping it the bearing!
__________________
Old 02-19-2007, 03:25 PM
thebufenator's Avatar
My car just failed for the same reason......
so.....whats the best way to diagnose what the actualy prob is?
Quick Reply: steering column is loose, anybody know how i can fix it?
