Stuck on Panhard Bar Install...
Got the nut off each end but I can't get the bolts out. I've tried backing them out by turning them with the wrench but they just spin in the bushing. I've tried banging them out with a 5 lb hammer with no luck either. I feel like such a dweeb.....
Originally Posted by shudog
that's what a buddy told me, heat it up good first.... too bad I don't have a torch!!! I thought it was just a simple bolt on!
it is maybe possible that the phb is under load, like if you lift the car and let the axle hang. If you make sure there is no strain on the phb and the bolts that hold it in, that may solve your problem.
seems like it's always under some sort of load, either tension or compression.... tension when the axle is hanging down, compression when the axle is pushed up.... I'll give it a shot again maybe this coming weekend. I really don't want to get out a torch but I suppose I could get a little portable propane setup....
Copy & Paste Moderator
Originally Posted by 3.4camaro
bang away at it like its Paris Hilton!!!!
Sorry I'm no help.
The bolts just came out of mine without any problem.
