question a/b tunnel mounted T. Arm
Old 03-12-2007, 06:43 PM
blksheep's Avatar
Default question a/b tunnel mounted T. Arm
recently purchased the TSP true duals set up, and i was wondering if it was possible to use a tunnel mounted arm. i searched, found some pictures and all the pictures have the tail shaft mounted arm....
if so is there any cons. on running the tailshaft mounted arm??
Old 03-12-2007, 09:24 PM
Duffster's Avatar
Yes, some account for the use of true duals. Downside...LOTS more noise from your rearend. Each and every time a spring moves, you'll hear it in the tunnel/floorboard. Just yanked mine after nearly a year. I had a non-adjustable one and never saw any improvement in traction, so, out it came. My opinion...
