Bone dry brakes system, any special tips on bleeding?
My entire brake 1005 z28 brake system is bone dry. I understand how to bleed brakes starting at the right rear and working toward the front left. I understand to not let the master run dry during the process.
Is there anything else I need to know when doing a complete brake fluid replacement and bleeding? Anything special to do with the master?
Thanks.
Thanks.
When I replace lines or the entire brake system on a car, I use a mighty vac to get the ball rolling. I still start at the right rear. Make sure the master is full. Pull some vac. on the bleeder valve, then crack it open for a few seconds. Close it off, pull more vac., and repeat. I do this at each wheel until I get fluid coming out.
Then I bleed them the conventional way. Bleeding brakes the conventional way is never failed me. You get a good pressure/rush of fluid through the caliper when you do this, so its usually plenty to pick up any air bubbles or whatever is in the dry caliper.
There is always gravity bleeding too which some people like.
Justin
Justin
Hmm...Well you might want to check on the ABS thing. I thought ABS cars got bled in a different order. But that might just be something i heard about other cars...
Otherwise the mighty vac should still work. If its a new master cylinder, or it is really really empty, bench bleeding it is a good idea. Then Ide try the mighty vac. You fill the master, and put the hose from the vac on the bleeder valve. Make sure you have the little container that comes with the mighty vac for the fluid to go into. With the bleeder valve CLOSED, pull a vacuum, then crack the bleeder screw. It only has to be open for a second or two. Close it back up, pull more vac, and do it again.
Im pretty sure that it will pull fluid through the abs block, and once you start pedal bleeding, it should take care of it. You might have to bleed all the wheels a few extra times, just to be sure you are getting the bubbles out of the abs block as well.
Someone that has bled the ABS system might chime in and give you a different procedure. I dont have ABS on my 87...I just ran everything right off the master.
Justin
Justin
