who makes the best K-member?
how to:
do everything you need to drop the engine, but unbold the engine mounts and keep the engine in the air, and thats it. My Spohn k-member came with instructions, but it's very straight forward once you get under the car.
But when putting it back on, bolt the driver's side steering rack bolt on before the passenger side!!
EDIT- and all of the above opinion are biased because UMI has the biggest presence on this site. No one has tested them until breaking point back to back. Either way, you will have a good product if you choose UMI, Spohn, or BMR.
We just installed a UMI K member and A arms last week, it was a piece of cake. Everything lined up perfectly , no issues.One thing that did make it awfully easy was that we had pulled the engine out the top the week before. One thing you really want to do is Gunk and degrease the rack and pinion, get it cleaned up and it will look brand new. Also do Energy Suspension or prothane end links.
Thick or thin, good or bad I will be on this site to help with our products.
Thank you,
Ryan
LS1TECH Sponsor
Don't you think that a presence is important? And anyone with even one working eye can see the UMI simple has more beef to it than the others. You say "no one has tested one to the breaking point and back". Maybe it's because it's strong enough to not break like some others have, which was the idea in the first place.....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
UMI is the **** I have there LCA w/relocation brakets, and ADJ.panhard bar. I love them good quailty parts and Customer service. Only problem is I wanted stickers to put on my car to pimp there name but they dont have any.
