~Need Anti-roll bar pics please~
it's a long bar that stretches the width of the car, it has 4 bolts connecting to the frame (2 on each side) and then a long bolt with a bunch of bushings that connect to each A arm. Not hard to replace or change at all. There is one on the front and rear.
:sigh: I understand that, and actually was expecting someone to make that comment.
However, he didn't make any mention of anything other than a stock-style swaybar, so I assumed he meant a stock replacement type, such as Spohn's 25mm rear swaybar designed for drag racing.
I want to see one on a car so I can make one.
And yes it is to eliminate any body roll....or sway.
All the ones ive installed and seen are like a rod inside a tube that pivots and has arms on each end with small rods and heim joints going to the axle.
Since the f-body is rather tight and confined i'd like to see how people have them, or if there is some different setup people are using.
