Can I use bolt in relocation brackets with a Moser 9"?
*I did try the search function but as usual it is not working.*
Just curious... I need to get some relo brackets but would prefer the bolt ins. I was just checking out the UMI brackets and they say they cant be used with aftermarket rear ends... but why? All of my stock suspension bolted right into my Moser 9".
Well.. can I use bolt ins or am I stuck with welding ins?
Thanks in advance.
Thanks in advance.
Hello,
Moser builds there control arm mounts much wider then the factory rear end. They also use a thicker steel. The brackets made to fit the stock rear ends will not fit over the Moser bracket. So in order to use relocation brackets on that rear end you must use this item- www.umiperformance.com/2011
If I can help anymore please ask. Thank you!
Ryan
Ryan
