C5 brake upgrade, worth the $$ ?
Old 07-17-2007, 01:41 AM
WonQuickZ28's Avatar
Default C5 brake upgrade, worth the $$ ?
Looking to upgrade my brake system, just wondering if its really worth the money to move up to a set of C5 brakes? I know theyre bigger, but by how much? Also, the the C5 calipers have more and/or better pistons? I work at an auto parts store so I can get all the parts 20% off, minus the conversion brackets that Ill get from UMI. Thanks in advance, any advice is appreciated.
-Tyler
Old 07-17-2007, 08:56 AM
Restricted User
Blakbird24's Avatar
Yes it's worth it, no they don't have more or better pistons. They are stronger calipers that can hold a bigger pad, and the C5 rotors are larger.
Old 07-17-2007, 11:42 AM
red devilSS's Avatar
i've done it and haven't regretted it. Although, in all honesty, i did it more for cosmetics then function. But, it has come in handy a couple times to have bigger brakes, especially when a knucklehead in front of you decides to do something stupid on the road.
Old 07-17-2007, 11:47 AM
i guess if it works better only once, its worth the money and time spent. there are a lot of douche bag drivers in tallahassee so I think Im going to invest in the upgrade.
Old 07-17-2007, 12:13 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
how much bigger are the C5's rotors over the LS1 f-bodies?
Old 07-17-2007, 12:32 PM
UMI Performance's Avatar
Hello,
Below is a list of benefits from the C5 brake conversion:
Benefits of Running the C5 Set Up
1. Larger Rotors: The larger rotor absorbs and radiates more heat, the C5 rotor is 1” larger then the LS1 rotor and 2” larger then the LT1 rotor
2. C5 Rotors are directional unlike the LT1 and LS1 set ups. C5 rotors feature fins designed to advance air flow allowing better cooling.
3. Many brake pad and rotor options are available for all types of driving
4. The C5 calipers are pressure cast not gravity cast, this helps increase caliper life
5. Unlike other brake set ups, C5 components can be purchased at any parts store. This eliminates down time when an item may fail or require quick replacement.
If I can help anymore please ask. Thank you!
Ryan
Old 07-17-2007, 12:46 PM
lo_jack's Avatar
I have Ryan's brackets and like them a lot.
Old 07-17-2007, 08:44 PM
ghardester's Avatar
Ryan
__________________
Ryan
UMI Performance Inc.
I just ordered my UMI C5 upgrade on Sunday from WS6 Store. I understand there will be a little spindle modification. Could you tell me what this involves? I know that there will be instuctions with the parts, but I would like to be prepared. PM me or ghardester@centurytel.net Thanks.
Old 07-17-2007, 10:20 PM
Step # 1 in the link below shows exactly what needs cut. The installation instructions included are very detailed. Once you receive the kit and look over the instructions if you still have questions please give us a call.
http://www.umiperformance.com/page.php?page=c5install
Ryan
Old 07-17-2007, 11:13 PM
ghardester's Avatar
Thank you. That's about what I expected it would be. Looking forward to the upgrade.
Old 07-18-2007, 04:21 PM
SpdFrk1990's Avatar
I bought the kit from UMI and love it. People always notice them and comment on them. I was at a drive-in last friday and some guy was checkin it out I heard him tell his friend look at his brakes they are red and say camaro on them. Then he was like no wait corvette wow. lol
Old 10-29-2007, 09:38 PM
krazykarl454's Avatar
hey i know the kits like $115 and standard rotors(autozone) are like 30 bucks each, but how much $$$ are the calipers? spdfrk1990 they look sick, would definetly fil lup my rims nicely, but more importantly. do they kick ***?
Old 10-29-2007, 10:08 PM
Wolfwoodx89's Avatar
ive been wondering. I just now noticed that all the c5 kits never include rear brakes as well. Do people generally only replace the fronts? While there is no doubt they look cool, would they really look good having corvette brakes in the front and then say brembos in that back? Or do people find kits with the whole package. are those even made?
Old 10-29-2007, 11:13 PM
02Z28LS1's Avatar
most people usually only do the fronts, due to the cost vs. benefit involved with doing the rears....although there have been several people on here that have done both front & rear. you should be able to find them fairly easily in a search to see what they've done to get it all set up.
Quick Reply: C5 brake upgrade, worth the $$ ?
