Wilwoods And 17inch Rims
Old 07-18-2007, 08:52 PM
Jpr5690's Avatar
Default Wilwoods And 17inch Rims
They Say Thell Fit But I Know Its Gotta Be Real Close
Anyone Got Expirence With Zr-1 Replicas And The 6piston Wilwood Kits
Old 07-20-2007, 11:58 PM
96silverram's Avatar
You definitely want to download the PDF file from Wilwood and look at the dimensional drawing. You will need to take some measurements from you current ZR1 rim and compare the specs against Wilwood's PDF file for the F-body setup. Wilwood's 6 piston caliper has a ton of overhang. In most cases it will take a 18" rim to fit their big brake kits.
I have the SL6 Wilwood 13" 6 piston front setup and the 12.2" 4 piston rear setup on my 96 WS6 LT1 car. My front kit is actually a LS1 6 piston kit, I just swapped the front spindles to LS1's. If your interested in the front kit I'm getting ready to sell it and purchase a larger setup. The kit has less than 10 miles on it since installed (obviously the setup is mint )
Old 07-21-2007, 03:05 PM
Jpr5690's Avatar
If Its Up For Sale Pm Me A Price
Old 07-21-2007, 11:17 PM
Carlos01SS's Avatar
Definitely download the PDF file, print the drawing and glue it onto a piece of cardboard, cut off what is not part of the template and take out your front rim and put it in the rim and slowly twirl it around and make sure it doesn't hit anything...If it doesn't, then you're golden.
I got the 17"X9.5" chrome Z06 Motorsports wheels from Tomzwheels.com and they fit just fine, no issues, haven't had any issues with the brakes other than they stop REAL GOOD!
Old 07-22-2007, 01:34 PM
Here's a pic of the front setup, this is a LS1 setup (I'm using LS1 spindles):
