Car feels "Jumpy" over bumps....HELP
Alright guys I'm not quite sure what this is or if every f-body is like this but i have a question....
Whenever I hit a bump my car feels like it jumps, if i hit a bump while accelerating (even under normal acceleration) it feels like my wheels spins for a second then comes back down to the ground.
on the highway when i hit a little bump i can feel the back end swing out a tiny bit, like it is sliding, but its only over bumps. on smooth road it is perfect.
I'm thinking my tires may be overinflated...? or is this a normal feel?
Originally Posted by JD_AMG
I know exactly what your talking about. Your problem is you have the shitty stock shocks.
ie. if one had double-adjustable shocks, what would one reduce with respect to the original-quality settings, the compression absorption or the rebound absorption. Or on the flipside, what would one increase?
Originally Posted by TripleTransAm
Out of curiousity, what is it about the stock shocks that would cause this problem?
You would turn up the rebound, causing the shock to expand slower after compression.
That's what I'm having trouble visualizing...
If the shock compresses on the bump, that's the whole wheel moving up into the wheel well with supposedly the car fairly level. Wouldn't a slow expansion of the shock leave the wheel off the ground after the bump and a more violent landing under power?
I would have thought one would want the shock to expand quicker and have the wheel follow the ground sooner. I must be missing some detail.
Any opinions on good LCA's that will eliminate the wheel hop?
also keep in mind when people mention unsprung weight... if you have an aftermarket rearend or heavier aftermarket wheels, or even heavier tires, those can all effect things as well.
in my experiences, it's worse with a gas tank less than half full
it's worse when my t-tops are on because there is no additional weight in the back (all I have in the back is t-top holders, nothing else, no subs or anything) because it seems to make the jolting feeling worse...
and it's worse when I'm the only person in the car as well.
just how I notice things I guess.
hope it helps, though somebody could tell me I'm completely wrong as well
I agree. It seems like the car isn't rebounding fast enough, but I don't know too much about suspension so I may be wrong. I'm not sure how LCA's work, but I think I will end up trying those first since it does feel like wheel hop.
you can get them boxed, you can purchase boxed, you can get rod (which most seem to carry now) with poly ends, rod ends, or a combo...
if you get poly mounts remember to keep them lubed, if not, you'll experience the same jolt feeling after hitting bumps (it took me awhile to realize this because I had little time to re-lube my rear suspension until recently, it makes a world of difference) ...
seems most people on this board seem to go with UMI or BMR, though lately the majority seems to be UMI (also who I decided to go with)... good products, good support if needed
LS1TECH Sponsor
The stock rear shocks have too much compression damping, and they DON'T follow sharp short bumps well at all, instead they resist letting the axle move up and over. Sticky LCA's will cause this too because they also can keep the axle from moving up and over.
Add lowering springs to the stock springs and it gets worse. Yet another reason why I always start with shocks...
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
I have rears, but no fronts--national backorder (going on 5 months now).
__________________
