Think my pinion angle is off
Old 07-31-2007, 03:21 PM
SpdFrk1990's Avatar
Default Think my pinion angle is off
I took her out on the highway last night and was going to open it up since I never tried much high speed in it. This was around 2am so not many cars on the road. Over 100 the vibration got bad I had it close to 130 but couldnt go any faster cause it just got too bad. I have lowered the car and I got a TA relocation kit which seems to lower the front of the TA a little also. If I got a adj TA do you think it would eliminate the vibration? B4 all of this it use to be pretty smooth.
Old 07-31-2007, 04:31 PM
SpdFrk1990's Avatar
Anyone?
Old 07-31-2007, 08:18 PM
Moderator
jimmyblue's Avatar
Try on and off the throttle, if it changes much then it
might be driveline angle, if it only changes with speed
and not pedal look for a wheel balance, bent axle, bad
shock kind of problem (though bad shock only allows
it to "bloom", not cause it directly).
Old 07-31-2007, 08:37 PM
SpdFrk1990's Avatar
Im pretty sure it was better once off the throttle. Im about positive its cause the pinion angle but I guess part of it could be the DS also since I will feel more vibration with the TA relocation. It never noticed it before the TA relocation and spring/shock install. The lowering plus the TA relocation prob threw it off a good amount.
