What are the effects of LCAs too low in the back?
I have weld in relocation brackets and put them in the lowest holes. I've noticed it seems to fishtail easier, it's controllable but is this because the rear of the LCA's are too low?
Just try the other hole, if it is better leave it there, also check the pinion angle.
With lowering or raising intersection points there is a sweet spot, going below or above it will cause you to loose optimum traction.
Try to borrow a set of good tires and test out which hole works better, it is hard to tell much from street tires.
LS1Tech Premium Sponsor
In a nutshell the more upward angle on the lower control arms the more it will cause the car to rearsteer. So when you put the car in a corner it is fighting itself trying to make the turn.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Lee Spicher
(813)986-9302
LS1TECH Sponsor
The more tail down you run the LCA's, the more rearward your instant center moves on hard acceleration, but the more squirrely the car gets. The more upward they are, the more stable the car is, which is why we run ours like this on handling cars. If you kind of want both, we simply use weld-in brackets that allow you any position from stock to ultra low and you can change that at the track.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I guess I should try the middle hole.
The stock location was terrible, it would wheel hop and fishtail to the point of almost wrecking, on the street.
Now in the lowest hole it just spins and sways side to side, feels controllable, but needs fine tuning.
