DMS springs just keep gettin lower
I installed the DMS springs and BMR LCA's and reloc brackets on the bird on Monday. After i was done i stepped back to look at her and was like "that really doesn't look much different"
tuesday it looked lower and the rear wasn't sitting even. Wednesday it got lower still and the rear leveled some. by friday everything was level and possibly a little lower, and after some "spirited" driving on some back roads last evening the thing looks SLAMMED today. Whats goin on here? is the suspension just setteling? I didn't measure after i first installed the springs but after i installed them i did the finger test. The back had a 4 finger gap between the tire and fender and the front was abotu 2.5. Now today the back is about a 1.5 finger gap and the front damn near tucks! She deffinatley looks sweet, i just hope she is done setteling and doesnt drop anymore.
Joe
Joe
Re: DMS springs just keep gettin lower
here is a pic http://bigjb.dyndns.org/b2.jpg
the springs have stopped gettin lower. It sits now pretty much as I described it at the end of the first post. It looks amazing, handles great, and I dont have any problems. I guess it was just the springs working them selves into place?
That is normal IMO. I have done some suspension work to my cars and trucks and they have all done that. U put new suspention on, it's stiff and needs to settle in place. even with stock suspention if u mess with it and put it back down on the ground it will be a lil higher cuz there was no weight on it. Just keep an eyey on it, it shouldn't drop any more. looks good tho
Can you measure the distance from the ground to the center of the wheel well when on a flat surface? I have read where people are measuring 26" in the front and around 27" in back depending on spacer/hose. I would like to hear what you measure because I am planning on DMS springs but I have square tube SFC's that hang down some. I have 5 3/4" clearance from the bottom of them to the ground. It does look though that my Y-pipe is as low or lower.
Yes they settle for a couple days. First time I took my car to a road couse it settled another 1/4" which it has not regained.
Your car looks sweet, but that is lower than I thought the DMS springs lowered it.
Yea, I'll measure that distance for you. I left the rear spacer in. I like the rake it creates, more of a muscle car look, rather than the totally level ricer look. I have boxed BMR SFC's and haven't had a problem with them, I do scrape my jet hot ORY from time to time, but that will all go away when i switch to true duals
I dont have anyother pics that are online right now. But i'll snap some more this weekend if you like
I will look forward for those measurements and maybe you can measure the distance to your SFC's too. I do agree with everyone it looks great and I agree with you on the rake. I am old school and like that look. I take it you have Jet hot LT's? No problem hitting those just the Y. That is good to know.. That is my next project after lowering. I want to run cats though. Thanks for the measurements in advance..
