anyone else running bmr springs?
LS1TECH Sponsor
I'd suggest taking your time here and doing your research. Pictures of cars and technical info (spring rates, weights, etc.) are things you want to learn about.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
well I already have them on and they're pretty stiff.(not a bad thing) just wondering how they compared to others in ride quality. I have LTs so I needed the littlest drop possible...otherwise I would have gone with your springs
what was your final drop measurement?
i've looked at BMR for the same reason. with TDs and 315s i need to be careful.
not to mention i have BMR all around already...be nice to keep that theme.
LS1TECH Sponsor
Bear in mind that the drops are approximate. My springs tend to really be about 1" in front, 1.25" rear. But that varies depending on the car. Most cars on our springs run 26" front, 26.75" rear when measuring ground to fender on stock diameter tires. Most LS1's start @ 27"/28".
__________________
LS1TECH Sponsor
I won't lie, I think the BMR's are workable, I just don't think they are ideal. I didn't think anything really was given all the things I've messed with which is why I spent the time and money to have springs made to suit me. They admittedly might not suit everyone, and if I'm honest I do believe you could do worse than BMR's.
__________________
I almost went with the BMRs, but I wanted a more substantial drop so i got a set of Sam's springs. I think with LTs you made the right choice by getting the BMRs. The stance isn't exacly my preference, but these are perfect for people who need to keep their drop to a minimum and maintain some ground clearance.
What shocks are you on? Are you looking for better ride quality or what?
LS1TECH Sponsor
The smallest drop you can get would be Koni's on the lower perch with stock springs (which is also the best ride you can get when lowering as well because you keep the softer stock springs). The shocks ain't cheap, but you also gain control and lessen impact harshness with them vs. stock. Or SLP springs, but I don't find them to handle much better than stock springs and Koni's.
__________________
LS1TECH Sponsor
It's my job to know... Knowledge helps recommend the best parts for the job. Anyone can say "buy this". It's harder to know what options exist and why some things are good, and why others might not be ideal.
__________________
LS1TECH Sponsor
And for comparison, Strano Performance SP141 springs also on a red Pontiac
__________________
LS1TECH Sponsor
That's true.
__________________
