I want my SS to handle better? I just want some ideas on how to get my SS to handle alittle better in the corners. I dont have a lot of money to spend I dont really want to lower my car. I was thinking new sway bars, maybe some better shocks. What do you guys think? |
See Sam Strano. His 3/4 shock combo and springs should do nicely. Also a set of f/r bars w/ poly endlinks will help alot. |
A new adj. panhard rod would be the best bang for your buck. New shocks and springs will cost you over a grand for the nice Koni/strano spring but would make a huge improvement. |
if you really dont want to lower... nice results can be had by koni 4/3 strano bars poly/rod panhard bar still cost a bit of money, but well worth it |
pm'ed u |
Start with better shocks. My Bilstein HDs were a noticeable improvement. I also have sub-frame connectors which I think helped a lot too but others will disagree. Even an instructor at an HPDE commented that the car felt better than stock. It does lean a little more than I want so I'm thinking about upgrading the sway bars. |
Originally Posted by BarneyMobile
(Post 8363340)
Originally Posted by Sam Strano
(Post 8369984)
Both good ideas. Shocks are the key, get the best you possibly can because they are the most in need of help, and the car itself is not a bad handling car once the shocks are addressed with good quality and correctly chosen replacments. From there we build as much as you want depending on what you think after the shocks go on. I rode in my buddies 06 STi and I absolutly loved they way it drove and handled. I was kinda aiming in that direction. Thanks again! |
This combo is proven and you WILL FEEL results. Konia SA 3/4 or 4/4 Sams front and rear bars double adju UMI panhard bar. Big DIFFERENCE. I have had couple of setups and this one is very nice! I think you will be happy with the results :) Also sam is a great guy to explain and help you, but this is a great combo! |
I will tell you this: Stick with Sam Strano and you will be fine. Do not bother going to someone else. Sam is who you need. |
(Post 8373078)
Thanks for reply, What shocks do you recommend for a dd ( I use the term dd loosely) I was checking out the SLP bilstien shocks or is that not a good choice? I rode in my buddies 06 STi and I absolutly loved they way it drove and handled. I was kinda aiming in that direction. Thanks again! The STi is quite firm and they handle well. I can make your car handle much more like that, but with a ride that has a bit less impact harshness. You probably liked the way the car was really tied-down feeling, firm, controlled, right? While springs and bars help that, it starts with the shocks, they are what control roll and pitch rates, the other things control the amount. But you tend to notice and feel the rates first. |
Sounds like Sam Knows his stuff |
I try.... :) |
i am in the same boat. i like the look of the lowed cars with sams springs, i just dont want to end up with a car that is not going to be tolerable to drive. i still want to be able to drive over speed bumps and go on lifts with scraping the nose and anything under. anyone have issues like that. |
Sooo... What is a good spring/shock set up for a car you want to lower 1.5 inch? I dont want the all out coil over suspension. Just stock style springs and shocks that will handle better than stock. |
(Post 8373078)
Thanks for reply, What shocks do you recommend for a dd ( I use the term dd loosely) I was checking out the SLP bilstien shocks or is that not a good choice? I rode in my buddies 06 STi and I absolutly loved they way it drove and handled. I was kinda aiming in that direction. Thanks again! https://ls1tech.com/forums/showpost....21&postcount=8 |
shocks are going to make the single biggest improvement. shocks arent cheap either so be prepared. |
Can't go wron with strano |
I dont even need to say anything but i will.... STRANO / KONI !!!!! That is all |
Originally Posted by slomarao
(Post 8384500)
© 2024 MH Sub I, LLC dba Internet Brands
