K Member Questions
The tubular design has a lot less surface area so it makes it a heck of a lot easier to work on the engine, remove and install parts. There's usually more room for larger components like headers and turbos, custom plumbing etc. They can be made much stiffer than stock welded stampings which is good for hard conering without deflection. But of course the biggest reason is it looks super bad ***.
Vernon
Vernon
Weight is one of the main reasons why they are used. They may only save 25-30lbs but combined with a few other items you can easily cut 100+ lbs off the front end.
Secondly, the additional room they offer for larger headers and turbo set-ups is a major plus.
If I can help please let me know. Thank you!
Ryan
Ryan
umi, whats the difference between road race and the original k member your selling. from what read, mainly more stiff? stronger? anything else. i think im going to order one.
If you have any more questions please ask. Thank you!
Ryan
LS1Tech Premium Sponsor
If you have any other questions regarding our product line please feel free to ask.
Do either of you guys offer the K-member in raw steel, before powder coating?
What I want to do is modify the unit to raise the engine, rack, etc... about 1" higher than stock. Basically as high as the intake to cowl will allow without rubbing. For the most part it looks feasible. The one issue that may arise is the area where the caster bushing goes.
Based on the experience you have, does it look possible to cut off the body mount and weld it back on higher or just fab a new one higher?
(The reason for all this is for a radically lowered car so all the clearance I can get will be helpful)
Thanks.
Thanks.
