Help me build my PArts list!!
Well I am pretty much finished with my power mods its time for suspension. Well I plan on buying a ls7 clutch. Touque arm and relocation. I like the spohn so far but umi might be a possibility. I already have spohn sfc's, and lakewood lca's. I guess I will prob get some motor mounts and trans mount as well. O yea I plan on keeping my stock 10 bolt.
Any sugesstions Im open for.
go with umi suspension. this is what i have but ill be putting big power to the ground. road race k member, upper and lower a arms, lower control arms single adjustable poly ends 4130 chrome moly, single adjustable panhard bar poly end and rod end, 3 point subframe connectors, tunnel brace with drive shaft safety loop, tunnel brace mounted torque arm 4130 chrome moly, qa1 coilovers in the front and rear. are you looking to replace what you have now or just add to it? also what are your power mods?
if you just want something to hook i would reccommend a single adjustable panhard bar with a poly bushing on the body and the rod end on the rear, and single adjustable with 1 poly one rod end or 2 poly bushings, and a tunnel brace mounted torque arm. nice set of coilovers or shocks would do you good out back to.
