Adjust ride height on QA1's
I've got the QA1's R-series, and i was wondering how to go about adjusting the ride height. I've got the spanner wrenches for it, b/c they have two adjusting nuts, I guess the newer models do. Which way do you turn the first nut,and the 2nd nut,etc. Any help would be great, thanks!
the amount the nut is raised, measured on the shock, is about half of what the raise in ride height will be (1/2" on shock, 1" on body). for small adjustments, just do a turn at a time. I always like to raise a little more than not, that way if i'm not happy and have to lower it, I just do that from underneath without having to take the wheel off again.
LS1Tech Premium Sponsor
The spring adjuster will probably end up about 3" from the top of the threads on the coilover. When you are adjusting the front I would make an adjustment and at the very least bounce the front end up and down by hand to get true ride height at that given adjustment.
