Lowering Question???
Im lowering my camaro this spring and already have strano springs that i havent put on yet. Im going to order the Koni 4/3, LCA Relocation Brackets, and Adjustable Panhard Bar. Is that all I need for lowering??? Thanks
When you lower the car, the angle of the LCAs will go downward from the axle to the chassis. This angle is worse for launching and can be more prone to wheelhop, but doesn't mean you will wheelhop. I rarely wheelhop, only once in a while and I have the Strano springs.
The relocation brackets can put the LCAs at an upward angle from the axle to the chassis which will help force the wheels downward during a launch. The cons to this is that during a turn, the angles of the control arms will pull the axle forward on the inner turn side and cause the axle to point in the opposite direction of the turn, causing more oversteer.
There's some info on relocation brackets for ya. You can decide whether or not you need them.
The adjustable phb can be used to recenter your rear end upon lowering the car. The axle under suspension travel moves slightly side to side, not just straight up and down due to the way the phb is connected to it.
LS1TECH Sponsor
I agree that you don't need LCA brackets when lowering. I also do not run them on my car, no need for what I do. No wheelhop either. To lower properly, all you need are the right springs, shocks that match and an adjustable PHB to re-center the axle. Basically what I put into my HP1 kit (http://www.stranoparts.com/partdetai...D=18&ModelID=7).
I'm not saying that some cars won't need other things if the continue to, or start hopping. I'm saying let's see. Here you have two guys already who don't have wheelhop issues without brackets, and both cars are driven quite hard. I don't believe in parts without a real-world reason. Not all cars require the same things.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Alright, I'm bringing up an ancient thread, but I have a question.
Do I REALLY need an Adj. PH bar?
I'm wanting to lower my girlfriend's '98 SS for her birthday present. It's stock other than repro. black motorsports, gears, and exhaust, and she does NOT drive it hard, so would it be detrimental to just skip the panhard bar?
Thanks guys
Thanks guys
LS1Tech Premium Sponsor
Thanks guys
Thanks guys
Our lowering packages are designed to help save you a few dollars and aid with some basic suspension component choices.
If you are looking for more of a recommendation for your particular application I would be more than happy to over all of the choices I have available for you
Thanks you; and i will def be consulting with you before i purchase. My car is going to be a canyon carver with some (light) track time just for bsing and fun. I'm more worried about handleing. I just don't want to spend 3K on an entire suspension re-haul if i don't need too; at least not all at once. Eventually i will have EVERYTHING done (k-member, sfc, ect) but right now i just ant to know what i need other then an adj phb. Also my car is NOT for competion and probably wont be either. It is just a street cruiser and show car.
it is just hard b/c everyone somewhere says you need everything. u kno?
And you definitely don't need to spend anywhere near $3,000 on suspension for a street canyon craver. Good shocks, springs and swaybars(matched together for handling, not all just thrown on from different companies, check out strano's setup, specifically designed together for handling) will be more than enough (assuming you have good tires) for suspension. You definitely don't need SFCs, or relocation brackets if you are going for handling.
