wheel hope and lowering question
so my car used to just spin tires when i hammered on it, now with a bigger motor and mods it wheel hopes so bad that i am afraid that i will tare the rear end out, so what would be the first thing i need to do to make the rear end stick, panhard bar, sub frame conn. tourque arms?????????????????????????????? also i have pace setter lt headers and was wanting to know if i can lower my car with out rubbing the road, i run 275/35/18 tires. thanks 2001 ta 6speed........
The lower down your lower control arm mounting point on your axle is compared to the lca mounting point on the chassis, the better off you are at curing the wheelhop and putting down better overall traction.
One guy in a local message board was doing 2.5 60 foot times until he put on lca relocation brackets. Now he's doing 1.7 60 foot times. There's probably some "learning how to launch" factor in there as well, but that's almost a whole second better.
hence why I said theres some learning how to launch factor possibly in there too. obviously not many can launch the same every time, and the more you do it you probably lower the time. Either way, that's a good improvement and sufficient enough for me to personally believe that the lca relo brackets helped improve his 60 times
Kleeborp the Moderator™
I'm lost. I can't tell if you are laughing at the fact that I suggested there's a learning period in getting your max 60 times down, or if you are laughing because there obviously is one in sarcasm.
I've never been to the drag strip before, just the local spectator drags that I participate in, so I can't really tell what type of 60's I'd pull my first time. But I'd imagine my first one won't be that great.
If it's anything like the local event I do, there's a learning curve there. It has taken me a few years to nail it down too, out of 4 events a year.
