LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Suspension & Brakes (https://ls1tech.com/forums/suspension-brakes-16/)
-   -   Car won't hook (https://ls1tech.com/forums/suspension-brakes/884860-car-wont-hook.html)
kratos2250 Mar 18, 2008 03:30 AM
Car won't hook
I have a 2002 camaro with about 400 horse, and can't get the thing to hook. What suspension mods do I do to help this out?
jessedale98 Mar 18, 2008 03:32 AM
kind of a weak question. List what you have!
But for starters you will need TIRES,LCA'S,TQ ARM,SFC'S,QA1 ADJ'S
kratos2250 Mar 18, 2008 03:40 AM
sorry I have a touquer v2 cam 3200 rpm stall with a set of mt's and I was at the track last weekend and it kept spinning off the line could'nt get it to hook for nothing
junior28570 Mar 18, 2008 04:43 AM
Was anyone else having issues launching? I pay attention to what others are able to do before I start questioning my set-up.
I'd recommend LCA relocation brackets and use the lower hole. Made the most improvement to my 60' to date. All those things jesse listed will help even more.
BORN2LOSE Mar 18, 2008 07:45 AM
Yep, LCA relocation brackets especially when the car is lowered.
BMR Suspension Mar 18, 2008 07:50 AM
Is it currently all stock suspension parts? or do you already have a few components replaced?
1Loudz28 Mar 18, 2008 01:03 PM
Lower control arms, relocation brackets, torque arm
kratos2250 Mar 18, 2008 05:50 PM
completey stock suspension and yes pretty much everybody else was launching
COOKIE MONSTER Mar 18, 2008 06:06 PM
Whats up dirtbag! he he
COOKIE MONSTER Mar 18, 2008 06:11 PM
Ok, heres what I suggest. Go to TSP or Maryland speed, order yourself some Spohn Adjustable Lower Control Arms, pick any color you want because spohn doesn't ass-rape you like BMR does when it comes to price difference over a damn color. lol Then get a set of LCA relocation brackets. Put them on the bottom hole. Also what MTs are you using? What gears?
linegtdt52 Mar 18, 2008 08:57 PM
Hold Up!!!
Here is what you do :
Call Dennis @ BMR and pick up
Bolt in relocation brackets for rear lower control arms
New tubular lower control arms non adjustable
TA001 Adj. torque arm
a set of QA1 on back to begin with
M-Ten Mar 19, 2008 03:43 AM
whoa whoa.. what about some good tires? suprised nobody said that.. throw some 315 nittos on there... I did and have no problem hooking up.. I only launch from about 1700 now though, cuz i get some slight wheel hop, but when i still have stock suspension.. so when i upgrade that it will be about perfect...
M-Ten Mar 19, 2008 03:45 AM
oh sorry guess you did say tires... but yeah that's the first thing you should do, no question about it :nod:
COOKIE MONSTER Mar 19, 2008 08:51 AM
I also asked what tires. Dont get non -adjustable LCAs, they're a waste of money if you're gonna continue modding your car. Also, for 400hp, you dont need damn QA1s in the rear to hook. Shit! I asked oyu what gears you got? if you have 4.10s I would suggest getting a set of Mt 135/13/17 ET Streets, or a 27 slick/cheater. Anything less you could use a set Nitto 555rs for. But first, get LCAs (Adjustable) and relocation brackets.
junior28570 Mar 19, 2008 05:58 PM
Originally Posted by 1BDTRAM (Post 8957924)
if you have 4.10s I would suggest getting a set of Mt 135/13/17 ET Streets.
WHAT? .. Come on now .. the man aint drivin' a mountain bike at the track! :chug:
sidewayz28 Mar 19, 2008 10:26 PM
my non adj LCAs are fine..
id say since you have tires you need an adj. torque arm, LCAs, relocation brackets and adj panhard bar
transamws6_97 Mar 19, 2008 10:47 PM
tires will make the biggest difference. if you are running a 10-bolt i would suggest just staying with drag radials. When it comes to actual suspension pieces from my experiences a chassis mounted torque arm made the biggest difference. It really pushed my tires into the pavement for great traction increase. The second most improvement was lca relocation brackets. and lastly subframe connectors really tied it all together and if you get a bmr torque arm you need sfc to weld the crossmember to. I had lca installed and they did absolutely nothing to increase traction. If you really think about the forces lca take the stock pieces are plenty.
DGraboyes Mar 20, 2008 07:05 PM
what helps eliminate wheel hop?
2manycars Mar 20, 2008 07:47 PM
FREE MOD!
More PSI in tires = More pounds in tire = Heavier tire that won't hop as much!
M-Ten Mar 20, 2008 08:34 PM
i hardly hop anymore since I put new tires on.. that's the first thing IMO you should do to improve traction/wheel hop.. then worry about the suspension, that's what i'm doing.
I get a small hop on launch, and sometimes a small hop going into second
© 2026 MH Sub I, LLC dba Internet Brands
