Rear control arm bolt size?
I'm trying to get my subframe connectors installed, however the rear bolt i have for the control arm isn't long enough, and I need a longer one. Can anyone tell me the size of it? I can't take it up to Home Depot because I only have this car, and running without a control arm bolted up would be a bad thing, lol.
LS1Tech Premium Sponsor
12mmx110mm will fix you up........
Make sure you get a good bolt that has a 10.8 marking on the head. It there is no marking you'll have no idea of the bolts strength. I've found that bolts at ace hardware tend to be better than the bolts at Home Depot.
