G2 suspension, what shocks/springs
What shocks and/or springs would complement a G2 suspension?(LCA,SBs,TA,PHR)
The trick is that I don't want my car lowered any!
I am looking at KYB shocks, but know nothing about springs that won't lower the car.
Re: G2 suspension, what shocks/springs
I would suggest 1LE front springs (if you can find them), stock rear springs, and either a 35mm ST front bar and stock 19mm rear bar, or 32mm 1LE front bar with 21mm 1LE rear bar. I would also skip on the KYB's for an F-body and get Bilstien HD's, or even SLP Bilsteins.
FWIW, the SLP built 1LE's ('01-'02) use the 1LE linear front springs like GM built '94-'99 1LE's, and same linear rear springs as a base Z28; GM built 1LE's ('94-'99) have stiffer progressive rear springs.
